221 - 226 of 226 Posts
No seriously, I'm not making this up, that is why the signal wire is shielded. Google knock sensor oscilloscope.
It's explained well here.
The fact the tech was confident back probing this wire without shorting it out makes me feel better about my resistor mod.
That says nothing about the ECU looking at bias voltage. In fact, the Ohms test he does in the second part of the video is what seems relevant to me. A quick google search tells me bias voltage is what the knock sensor needs to operate and says nothing about why the ECU would need it, as it has its own power source.
The fact that it's shielded is explained by the way a piezo device operates. Noise on the circuit could cause the piezo element to trigger a false positive, not that noise to the ECU will. Your explanation seems to be that the ECU has a piezo device or oscilloscope functionality. My explanation is that it has an acceptable resistance range it's looking for. The same as a temp sensor and many other simple sensors that have been used in automotive and other engine systems for decades.
I've implemented a mod on my old atv to correct a failing temp sensor using a pot to adjust Ohms read by the fan control module. Ohms is what triggers the FCM to kick the fan on, not voltage. It's not as complicated as you're making it out to be.
Also, if you think the knock sensor can still function with your resistor in the circuit says a lot about how much you understand how all this works. You likely have an open circuit past that connector.
I never said it was smart. It's a simple piezo device that changes the resistance in the circuit when it encounters noise and has a normal resistance of 540k when all is well.
I'm going to be as diplomatic as possible in a final reply. When it becomes patently clear to everyone around that a party knows little to nothing about DC circuits, signal processing and what a piezo electric circuit can and can't do. That party should summon every bit of humility and cease contributing to the conversation as it adds nothing and only serves to muddy the waters.
