2004 Xterra 3.3 NON SC automatic. 185 miles.
This had a Left bank catalyst code and leaking valve cover since we picked it up 3 months ago. But ran fine.
Decided to tackle the leaking valve covers, replace fuel injectors (complete rail) from our wrecked 03 Xterra that had 6 month old hitachi injectors. And replace the drivers side ex manifold/converter.
Pulled the intake, swapped out the fuel rail/injectors, new valve cover gaskets, started the left side ex manifold, but backed off when the ERG tube would not budge.
Replaced the manifold and installed new fuel filter.
Upon completion it fired right up but idles poorly on and off. (idles fine for 20 seconds, idles crappy for 15-20 seconds, back and forth)
And I have codes P0132, P0138, P0152, and P0158
I added a heavy ground wire with soldered eyelets from the intake to the passenger cyl head,, ground wire from Neg bat terminal to body, and from Neg bat term to each ex manifold.
Cleared the codes and it seamed to idle fine,, but the codes came back and the poor idle returned.
I used a new Felpro upper intake gasket, but had to remove the ERG valve to install the intake, and re-installed the ERG with the old gasket.
I also had to replace the drives side down stream O2 sensor (damaged it during my work) grabbed a 6 month old one from the wrecked 03 Xterra and had to splice the 04 plug on it (soldered and heat shrink)
I know, a ton of things going on,, but why the same fault on all 4 O2 sensors ??
Where should I start,, I know all 4 did not go bad, I know the wiring for all 4 did not go bad.
Any direction I should start looking ??
