1 - 16 of 16 Posts
I have an '09 that I would like to mount a secondary alternator to run my on-board welder. I'm not seeing a lot of space for it, but am curious if anyone has done it and how.
Also looking for some suggestions for a dual battery set up.
thanks,
John
json, what about that welder that trailchaser had?
I think if mean green makes one it will power the on board welder. I know we can run one that way mike. but the alt is like $300 bucks
you'd have to check on 4x4parts.com to see if one is avaiable for an '09
Not to mention, you'll have to upgrade the alternator wiring to a bigger gauge...I asked 4x4parts about that and thats what they informed me before I backed out on getting one.
Hmmm...secondary gel cell batteries, installed OBW's, bt no secondary Alt's.
I can't think of a 2nd Gen with a OBW actually.
What I would do is get a higher amp alternator that would mount where the OEM went...there are a few sources, but an easy option would be like this:
https://www.4x4parts.com/catalog/product_info.php?products_id=5278
And yeah - you already know you need to up the ga on the wires that have more juice to carry, etc, like this:
https://www.4x4parts.com/catalog/product_info.php?products_id=5280
Then do an underhood control unit set up like :
https://www.4x4parts.com/catalog/product_info.php?products_id=775
Hope that helps!
:D
Hope that helps!
:D
Sounds like it'll run you over a thousand bucks if you bought all that stuff that TJ have posted up there.
Thanks TJ for the link to the upgraded cables, I have bookmarked it for future mod when my alternator needs an upgrade.
to run trailchasers welder he runs 2 car batteries on a cart that has wheels and with that setup he can weld for 1 straight hr before needing a charge....
LOL
Yup
But, after he bought a second alternator, and so forth, he'd be spending it anyway to do right.
I mean, you can stick weld with two sets of heavy ga jumper cables and 2 batteries, if you have some rods....w/o all that hoo ha.
Of course, a stick weld like that is really ok for a trail repair, but its not going to be pretty.
:D
yes he talks about a welder in the 2nd to last page but he dosent show a pic of it yet... i thought it was funny cause at the beginning of the thread he said he wasn't going to SAS it but now it is.. LOL
i just read all of the tread and i wish i had the money to do half the stuff he did to mine.. LOL
Discussion Starter #16
wow, thanks
this was my first post and I am amazed and pleased with all the thoughtful responses!
Actually I bought a Premier power welder (an old one) on Craigslist for $200 with a 140 amp alternator. I was hoping not to use it as my primary charging system and isolate it so I wouldn't have to worry about it affecting my warranty or wiring (i hate electrical issues!). I've read about using it as a stand alone and just need to mount the second alternator.
thanks
1 - 16 of 16 Posts
