2000 Xterra 6 Cyl 2WD.
Every time I check the oil, the oil on the dipstick is at a different level on each side of the marks.
Say I pull the dipstick out and wipe. Put it back in then pull it back out. The oil on one side of the marks says 1/2. If you look at the other side, it reads full.
So which is the correct reading?
Seems the mark is at 45 degree angle when it goes into the oil pan.
