Took my X in the other day for simple maintenance and the dealership noticed an oil leak towards the rear of the engine. I took a pic where it seems to be dripping down. I checked the dip stick and the oil level seemed fine. It's almost been 3 months since the last oil change and I was getting ready for the next.
How concerned should I be? In the past I'd probably just ignore this but I've been taking really good care of my X.
That looks like a power steering leak at the pump...double check your siphon and return lines going to the reservoir to make sure they aren't leaking...mine just needed to be tightened a little on the hose clamps, but even if you replace the hose, it's a 20 buck fix max...if you aren't losing oil, that's where I would start
Darin
01 Xterra SE 4x4
COMING SOON:
Wish list:
Darin
01 Xterra SE 4x4
COMING SOON:
Wish list:
Hmm, I'll check the power steering but I for sure have an oil leak. If it's been three months and the oil level hasn't changed do you think I am ok? I want to continue modding but I don't want to sink a bunch of money in before handling something that could be really bad for the engine.
If the oil level isn't going down its not oil. Looks like PS fluid.
