1 - 1 of 1 Posts
Had an oil leak from the valve cover gasket. Probably gaskets but so far I've only replaced the passenger side. Twice actually as it it still seemed to be oozing so I RTV'd it the second time with the gasket. For some reason this hose still has oil on it. I can't tell for sure if it's coming from above or this hose itself. (Starter is directly above hose in photos and the drain plug from the oil pan is visible)
Following the hose back it looks like it is part of the ABS and it leads into the bell housing on the transmission. Anyone know what this is?
2004, 126K 4X4.
1 - 1 of 1 Posts
