1 - 2 of 2 Posts
Hi All!
I'd like to say in advance I appreciate your help, as this one has me really bent out of shape (I keep stalling in a parking garage, and if you've ever been in one where people can't pass around you and there's no room for the tow truck, you can imagine why I have to get this fixed!)
Anyhow: 3.3L 2001 Xterra, auto, 4 wheel drive, hesitates or stalls when you let off the gas and try to get going again at stop signs, etc. More likely to stall when in that spot in-between letting off brake and putting gas pedal on. It has no check engine light, no codes. All vacuum hoses have been checked, all wiring, and it has fresh gas and a new fuel filter. It is running at a normal temp and all coolant hoses are fine. Ideas????
THANKS!!!
Aaron
could be a distributor. Take the cap, rotor and secondary cap off and check for bearing shavings. If you see that. then it's the bearings on your distributor.
1 - 2 of 2 Posts
