Hello, I have an 05 Xterra for almost a month now, and I'm loving it.
Since I bought it it has show me low oil pressure in low revs which I thought normal.
Today I drove around 600 miles and parked it for 2 hours, when I turned back on. It had no oil pressure at all.
The needle doesn't even move. It does has enough oil and I change it 3 weeks ago. The temperature is perfect and It doesn't present any wired sound.
I was afraid to run it but because the temperature was perfect I drove it the last 10 miles of the trip to make it home and it still working perfect.
I've read a lot of post similar to this but none that explain this particular case.
Could anybody give me a hand of what's going on? does the pressure sending unit fails and this is just a sensor issue? what would you guys recommend to find the problem
thank you
thank you
