1 - 4 of 4 Posts
Any ideas on what to check for this?
I did remove my front bumper and the fog/side marker lights are just chillin. I did tape them off though. Passenger fog light connector is broken but again I have it taped off.
That's the only thing I've done really, I know the wiring for my plate light on driver side is messed up, is that connected to the circuit because they may or may not be touching.
Discussion Starter · #2 ·
I just went to double check, the rubber coating of the driver plate light is compromised and I'm pretty sure theyre touching. It's too late at night to fix it right now but tomorrow I'll either tape those up or disconnect them and see if fuse still pops.
Yep it was the plate lights that were touching, I taped them off and put a new fuse in and everything works. If you have this issue make sure no light wires are touching
1 - 4 of 4 Posts
