In addition to the above, since the belt broke it is entirely possible that one of the cam shafts had an extra rotation with the same result as stated above. It is easy to assume that because all of the marks line, the timing is correct, but the only way to really tell for sure that I know of is to take the valve covers off and check the valve positions as you rotate the crankshaft manually.
Another possibility is that the new belt was not tensioned correctly and has jumped a tooth or two, throwing the timing out, though my money is on one of the camshafts being 180 off. It would mean that you are basically running on 3 cylinders. I wouldn't run it until you check it out. If you get detonation at the wrong time you could do some major damage.
