1 - 9 of 9 Posts
and how do I go about getting live data?? this code as become a pain,, I'm almost to the point of doing the
spark plug defouler thing, and being done with it??
Suck a little seafoam into the intake via the evap port with the motor running. If the engine compartment fills up with smoke, you have an exhaust manifold leak.
http://www.clubxterra.org/forums/showthread.php?t=15265
That said, I have no idea if a leaky exhaust manifold is sufficient to cause an O2 sensor code. Mine leaks like a sieve, but other than the puff puff puff sound I now hear constantly since I did the above myself, it's not causing any apparent trouble.
Check your wiring, clean contacts, add dielectric grease, and do that for every connection you can find
Darin
01 Xterra SE 4x4
COMING SOON:
Wish list:
1 - 9 of 9 Posts
