1 - 9 of 9 Posts
New to this form I have a 2002 nissan extera and going to do the rear differential oil change what iv saw on some other forum I need a 1/4 normal ratchet for one of the two plugs but what do else do I need as in does the 2002 extera have a hex screw also or just the 1/4 normal rachet end on both drain and filler screws thank you in advance.
thank you I appriciate the info it helps alot iv read alot of things on this form and its helped me with a few other things that I've needed to know and didnt have the knowledge for.. I actually have one more question tho pertaining to the differential you know what torque specs the bolts around differential plate need to be torqued at for my 2002 nissan extera?
Discussion Starter #5
Differential plate?? Not sure I know what you are referring to? Have a picture?
Discussion Starter #7
Hey sorry about that what I meant by differential plate was I know on 2002 and above and most trucks theres a plate that goes over differential gears that has the 10 or so bolts around it to hold it on but I belive mine is a sealed differential in back didnt mean to confuse anybody. I guess I just need help with the bolt size for dran and fill plug again I had tried a normal 1/2 but it was to small so is there a special tool or is a 3/4 racket end?
2003 SE 4x4 V6 100k miles
That bolt should be 1/2”, maybe you’ve stripped it a bit and it won’t work now, I did that with my front differential.
Discussion Starter #9
Heyy sorry it took me a while to get back guys sooo.. I feel dumb went to auto parts store and sure enough they let me test a 1/2 drive on my drain plug and it was it. I failed to realize that I had a 3/8 drive rachet and thought it was 1/2 for some reason so thank you for the help next is changing belt that goes around fan, water pump, and power steering pully anybody have a diagram mine is a 2002 nissan extera thank you in advance
1 - 9 of 9 Posts
