1 - 2 of 2 Posts
I just had my TPS, knock sensor and Idle control valve along with new fuel injectors replaced. Got everything back together and now the code P0505 keeps coming up. I can't shift into any gears it just keeps revving to 3/4 rpms. Checked the voltage coming from the PCM to the TPS getting 2.5 volts not 5 and the TPS position might be off but can't find the right specs for it. I tried to do the idle air volume relearn as well but the moment I try to restart the engine bogs out. Please help!
Check for any leaks...could cause this issue if the intake system isn't sealed up right
Darin
01 Xterra SE 4x4
COMING SOON:
Wish list:
1 - 2 of 2 Posts
