Alright update again. I apologize for the delay.
So I decided to take a step back and read the service manuals and a few other entries on the forum. I drove the car around to warm it up and then I followed the service manual on checking the timing on the engine. I found out that the timing was pretty close to 0° instead of the 10°-12° that it should be. I had timed the engine after installing the distributor, however the engine wasn't warm so I am not sure if that is why It's not accurate. I re-timed the engine, following the service manual.
Once the engine was properly timed. I have noticed two things
1. The roughness has reduced, it feels almost back to normal.
2. It hasn't stalled on me in the last few days.
The only issue that remained was that I can't just put the key in and start it. I have to turn the key to ignition, allow the fuel system to pressurize, then I can start it. If I don't, it cranks 10-15 times then starts.
Since re-timing the engine, I have driven it for almost a week without stalling the engine. However, today new issues have arrose.
I was driving and the engine once again went into limp mode, however this time it was different. It was more of a "womp womp womp" going 20mph. I couldn't accelerate faster then that. I now have 3 codes.
- P0731
Gear 1 incorrect ratio
- P0101
Mass or Volume Air Flow A Circuit Range / Performance
- P0103
Mass or Volume Air Flow A Circuit High
The P0101, P0103 lead me to believe that the MAF sensor is indeed bad (weird, because I tested that prior to the dizzy replacement).
Should I try to swap out the MAF with a Hitachi and see if that resolves the issue? Any thoughts on the P0731?
Video of "womp womp womp" sound.
IMG_1106.MOV
