Hi guys,
Recently put my X back together after neglecting it for almost a year. Changed the valve cover gasket on driver's side, changed plugs and the gaskets on the plenum. Vehicle runs great for about 10 minutes then acts like it is having a compression problem. As far as I can tell, all the vacuum lines are back in the correct place. Also, there is a small black electrical connector that I can't figure out where it connects. I have attached pictures of the connector. Any insight would be appreciated.
Thanks.
Thanks.
