2000
Xterra SE
4x4
v6 3.3
Auto trans
23x.xxx miles
I’ve had it 5 years.
What I know:
I was driving along just fine, and when stopping at a stop light, the car sputtered and died. Hasn’t started since. It’s been two days. It will turn over, but won’t start.
I replaced fuel filter (which was way over due). Still nothing.
Fuel pump works. I tested it by removing fuel line from fuel filter and turning key on (fuel shot out strong for 4-5 seconds.)
Tested fuel pump relay and fuse—both work fine.
The rotor under my distributor cap won’t turn when trying to start the car. (One guy on Youtube says this means the timing belt is broke??) The distributor cap itself looks perfectly fine.
Haven’t changed the Timing Belt since I’ve owned it. Not sure if it ever got a replacement from the new one. I know I need to get on that ASAP, but don’t want to assume it’s the culprit for my current situation…
Additional info (not sure if applicable)
I replaced my radiator about 3 months ago. Ever since then, my engine temp has been reading really low. There have been a few times, while on the highway for 20-30 min, where I can get the gauge to read about 1/3, but that’s as warm as it will read. I dumped about 16oz of coolant and filled about 16oz of just distilled water, hoping that diluting it would help bring my temp up. But nothing. If anything, it’s been reading colder. It’s been at least 2 months since I’ve seen my gauge read above the lowest level. In fact, I’m not sure it’s budged at all in a month or so.
It’s winter where I live. 0-32F on average for the past couple months.
There have been about 3 or 4 times in the last several months where my car had a difficult time starting cold. Both in warm and cold climate. 99% sure it wasn’t battery related.
ABS light has been on for about 4 years. Goes off when driving in 4x4 after a while. (Again, probably not applicable, but want to get ALL my skeletons out now...)
While researching my current issue, I’ve read everything from ...
- dirty MAF sensor
- bad Engine Temp sensor
- faulty Coolant Thermostat
- bad Oxygen sensors
to…
- corroded Fuel Gauge Sender (Fuel Sending Unit)
Haven’t dug into any of those options yet.
Any ideas where to go from here?
Thank you guys in advance. I’ve lurked around the forums here off and on for years.
Xterra SE
4x4
v6 3.3
Auto trans
23x.xxx miles
What I know:
- dirty MAF sensor
to…
