Hello all, I have a 2004 X with a bad transmission, I am wondering if other year 1st gen xterras have identical transmissions I could swap into mine?? Mine is supercharged with 180k milea.. 4x4.. any help would be greatly appreciated!!
2003 SE 4x4 V6 100k miles
I believe so. Automatic? The SC transmission is supposedly a bit beefier than the NA and so you could run into trouble getting the NA version, but it might be something like the torque converter that is stronger in the SC so you may be able to use a better torque converter with the NA transmission and be all set. But I’m theory the transmissions are the same throughout 00-04 model
Needs to be a supercharged trans or the 3.5 pathfinder may work. The supercharged model has an extra revolution sensor that the other ones don’t. It will code if the TCM doesn’t see that signal. Not sure if trans and computer can be swapped together. That’s similar to what I’ll be doing soon and hoping the regular transmission doesn’t blow up
