Hey guys I have a 2001 Xterra 4x4 with a JDM motor installed with 55K miles and every time i drive it uphill it cuts power and sometimes turns off however 1st and 2nd gear seem okay at lower speeds. I have this problem past 40 mph. So i been reading online and calling some mechanics around town and they claimed it bay be the O2 sensors or the catalytic converters. Thus I bought new O2 senors and new cats and installed today and same thing is happening. I did the motor swap myself with a help of a master technician. We cant seem to figure this out. Also I had an aftermarket intake kit on but i recently bought OEM intake from a junkyard. I have been reading a lot online and most people claim it was their catalytic converters. I checked my TPS sensor with a volt meter and it seems fine. I havnt checked my CPS, but wouldnt it throw a code with a OBII computer?? Is my tranny the issue or my torque converter?? Has anyone had this issue and fixed it? I feel like its something so simple. I have NOT checked the fuel pump too but that should throw a code! I am going crazy, please help! thank you.
How's the tps? Just curious, thinking maybe under heavy load it just is outside voltage parameters or something
Darin
01 Xterra SE 4x4
COMING SOON:
Wish list:
I haven't touched the TPS only because it should throw a code on any OB2 system and it doesn't. It doesn't show any codes on this cheap ob2 auto-zone brand system. I am still waiting for my mechanic friend to bring his professional scanner in. Till then Im still pulling out my hair!!
It will only throw a code when it is not within range all the time IIRC, sometimes if it is intermittent I have seen them not throw codes, but under acceleration, it was failing, of course that was on a crap-a-lac...idk, just food for thought...also, have you checked your TB to make sure all the vacuum lines and such are clear and functional?
Darin
01 Xterra SE 4x4
COMING SOON:
Wish list:
