Here is the problem.
There is a vibration, more like a low frequency rubbing sound, similar to driving with no rubber bushings on an A frame trunnion but only when X turns left even 5 degrees from center.
But only left turn about 5 degrees of steering wheel left thru.
these are the things I have done. New:
- wheel bearings
- cv joint axles
- lower steering box
- power steering pump
- rotated tires (these are new - have under 8K on them)
- the ball joints, tie rod ends appear tight.
- the shocks have about 30K the brakes are 3/4 new (30K) though there is some grooving but no warp.
there is no pull to the right or left.
the tire wear is even.
But I do have an ABS light.
anypone out there who knows enough about the X to tell what might be the cause?
