2004 3.3l Xterra, and it has a huge oil leak. It drips when not running, but after its warmed up it straight pours out like water. It's very bad. It's mainly coming from the center bottom hole in the bellhousing, but I also see some on both sides of where the tranny meets the engine, and all the way down to the bottom center. Valve covers aren't leaking. I have never in my life seen such a bad oil leak. Is it the rms, or oil pan gasket?? Is there any way to get a look at the back side of the pan gasket to see if it's the problem???
