41 - 60 of 65 Posts
mx592 - Can I be one of the BETA testers?
Discussion Starter · #42 ·
Sorry, beta testing is over! But I did lower the price, it is now $145 plus shipping.
Everytime I take a wheel off or anything I clean the area and repaint with camo green or that rubber undercoating, that shit is awesome.
Discussion Starter · #45 ·
Salt on the roads. Mine was 12 years old and had about 115k miles on it. While there was rust elsewhere on the car, the lower radiator support was the worst.
Salting the roads should be illegal, damn.... I lived on Padre Island for the past 10 years and its not very rusty at all.
Discussion Starter · #47 ·
FYI I am doing a 10% coupon code for the month of January and I currently have 5 pieces in stock. Once these are gone, the discount will be over. Code is XTERRA10.
Thanks
Hey guys, perfect timing. Just came from the mechanic (for a tune up) and they said they wont do any work because my radiator support is badly rusted. I finally came around to decide to do a tune up on the X cause it has been behaving weirdly. However now I am stuck and unsure, as much as I want to keep it, I cannot afford all these repairs and I do not have a garage. Anyone in Columbus Ohio area know someone who can do some decent work or a garage I can rent? Plus any advice if I should keep the X would be appreciated. (137000 miles, needs new spark plugs, belts, 02 sensors and both rear cats, has rust around wheel well on the rear)
Discussion Starter · #49 ·
I have a couple ready to ship if you decide you need one!
Here are pictures of my work so far. A little background: After the winter I noticed coolant dripping from under the X. Traced it to a leaky water pump seal (tip of the day - don't trust shitty NAPA parts). I did the timing belt and water pump with a local mobile mechanic (DZ Mobile Mechanix if anyone in the Hudson Valley needs help - he's awesome) and in the process decided to pull apart the entire front end to do miscellaneous other maintenance (like the corner lights, the below bumper support, etc). I was going to look into getting the whole OEM part for the support and just cut away what I didn't need, but happened upon this thread which has been a god send.
The tie bar as I was about to pull it off:
Left side tie bar mount. I separated it from the body with a chisel. Rust/corrosion went a little further up than some.
Right side tie bar mount. I had removed the rubber feet from the bottom of the AC condenser - thankfully they were still in place.
As MX592 mentions in his directions, the bolts holding the bumpter supports in place are VERY prone to snapping. This one didn't even budge before it just snapped right off at the head. (Left side rear)
And the right side front also snapped as I had it about halfway out - I tried to finesse it but it just wanted to be a dick.
I used some shims to support the radiator on the frame on each side. I measured to give people and idea of how much "lift" is appropriate:
The old tie rod after a little stress relief:
An example of the corrosion we experience as Xterra owners - this is after the tie bar was removed and before I cleaned away the rust and hit it with Rust Reformer spray and bed liner:
Getting the new bar in place to drill the mounting holes:
For anyone worried about "what happens if the tie bar gives way and the radiator drops" - I took a picture of the distance between the radiator shroud and the fan with the radiator sitting on the frame with no support. You could "probably" get away with no support, but I personally wouldn't risk it:
New tie bar in place:
Left side bolts in place:
Right side bolts in place:
Any questions and constructive feedback welcome.
I thought the included bolts would be too short since there was still a little gap between the bar and the body due to a weld on one side that I didn't bother to get rid of. But once you tighten them down they do the job perfectly. I'll post additional pictures once I have all the accessories back in place (windshield reservoir, mount for the horn and ari bag sensor, etc). I already redrilled and tapped the two seized bolts, just need to get new bolts for the bumper mounts to start buttoning it all up.
Do you have a guide how to remove the front grille and bumper? also how you got the broken nuts out?
okay guys, I've sold the X and haven't had time to do the support so I have it with me, still unopened. I will sell it and ship it cheaper if anyone needs it, pm me.
I've owned a 2004 Xterra XE since new, with 109K miles on it. Typical stuff, rocker panels are rusting and #6 cylinder misfire, and headliner detached. But overall a great vehicle, easy to drive, sit high, turns nice. My wife drives it.
It failed state inspection because of the lower tie radiator support being rusted through. I bought the replacement radiator support bar from Z Precision a year or so ago in anticipation of it failing. Found a local body shop who charged me straight labor, and did the work last week. With the photos and step by step instruction from Z Precision, the shop had no issues with the install.
Passed state inspection yesterday with flying colors. Thanks Z Precision! Excellent product and customer service!
Discussion Starter · #56 ·
Thank you for the wonderful feedback!
Reactions: MeToo and paboxcall
Hello guys –
I am new to the forum but I have owned my ’04 XE for about four years and I have lurked on here from time to time. I recently tackled the project of replacing the rusted out front radiator core support. I live in Michigan and the salt obviously got to it – the radiator was about to fall out of the car!
Anyway, I know this is a common problem on 01-04 X’s and I was surprised that nobody sells a replacement piece other than the entire front radiator support assembly. I did find a few sites that had just the support piece for sale, but all of them were either out of stock or unavailable so it seems as though you can no longer buy just this piece.
I briefly considered buying the entire assembly an just cutting out the spot welds to obtain the piece I needed, but that seemed like a waste and I have also heard that these parts are made from thin gauge sheet metal which will just rust out again in a couple years so I decided to fabricate my own from stainless.
The welded assembly I created turned out well and fits great, but it got me thinking – this piece could be made from a single piece of laser cut and bent stainless. I went ahead and modeled the part. A screen shot is below.
My question is, would anyone be interested in buying these? I have not yet gotten a production quote but that would greatly depend on purchase quantity so it’s hard to say what they would cost. I’m going to say somewhere between $100 and $200.
I’m just trying to gauge interest – I already put the engineering time into it so I figured I might be able to help out others as well as recoup some of my development costs!
can anyone build or supply me with this bracket - it's perfect
Hello guys –
Discussion Starter · #60 ·
41 - 60 of 65 Posts
