1 - 4 of 4 Posts
OK i have been slowly getting the Eclipse AVN head unit put in and hooked up. I am at another sticking point. I am looking for the VSS wire. I have looked all over here for a diagram or some pictures or something that will help me locate this little guy. But no luck. can some one send a diagram or explain where to find this a little better. I am in a 2004 with out the RF Factory stereo.Thanks
I also have an Eclipse AVN HU in my X. The VSS is a green/black wire in the gauge cluster or the ECM. In the gauge cluster, I belive its in the right side plug (there is 2 plugs on the bottom of it) And in the ECM, its in pin 29, The ECM is located below the heater box to the right of the accelerator pedal, behind trim panel. The VSS is in the 2nd row from the top, 4th pin right of center of the plug.
1 - 4 of 4 Posts
