So my x sprung a leak at the oil pan gasket.. so it only makes sense to go ahead and install a lokka and do the diff drop.. so.. heres my question.. ive racked my brain over gear ratios, spline count etc... heres my door tag info.. am i good to get the lokka? And diff drop bushings on 4x4parts.com?
Hg46
RE4R01A
Its a 2001 4wd
Thanks!
2000 Xterra XE 4x4 3.3L AT
RE4R01A is a transmission designation really has nothing to do with what you’re looking for here.
HG46 is the code you’re looking for. R200A open front diff, all the R200’s are open, with a spline count of 29. H233B rear came as either open or LSD with a spline count of 33.
The 46 in HG46 is the gear ratio yours has 4.6 gear ratio.
Discussion Starter #4
I think i see what ive done and why i screwed myself up in my thinking... the R200 is the front which is 29 spline so good to go with the lokka. The rear is the H233B which is 33 spline.. hence my confusion on a 29 spline lokka working.. but its the rear so.. yay for my blonde moment
