off the top of my head 2 screws above the cluster, 2 more under the heater controls. Then pull to release all the clips for the dash surround. Careful not to pul too hard as you have the switches you have to unplug once you get it out. Then i think theres 2 screws on the bottom of the cluster. At that point you should be able to pull it out. Disconnect the harness then you need to open the cluster (not sure never done that) The bulbs are pc74 i believe.
