So I have a issue I wonder if anyone can help..
The passenger side of the engine is leaking oil into the exhaust and it is smoking white... So could the head be cracked ??? Im not losing radiator flud .. Im hoping head is cracked over piston rings if anything... Pls give me some insight to what you guys feel it could be.. Oh yeah and my exhaust manifold is also cracked as well...
Honestly if its an R50 just bite the bullet and replace them with new cats, idk what state you live in but I will say this my R50 had 2 large cracks on driver's side and right by egr bungalow due to consequential damage from oil seeping on the header over time the issue I have in CA i used after market geaderd looks cooler louder but they would not match 6 point cat from r50 I used some from a frontier federal approved on ebay only because my smog guy won't fail me for visual however catback on mine rusted to hell I tried 3 diff companies to get a doug thorley catback or even a gibson no luck backorder and bad customer service ended up getting an oem aftermarket catback just need to get it welded on... Godspeed Goodluck my Friend
