1 - 14 of 14 Posts
Was about to pull the trigger on KMC XD Heists (16x8, 6x4.5, 10mm), for my 2006 Xterra X 4wd but then saw on several websites that these "would not fit my vehicle". I know a couple of people have ran these and said they did not use spacers. (I know my stock rims are 16x7, but my tires will fit a 16x8 platform. Did not know if that's the issue or if it's the offset) Any info would be appreciated! I'll attach an image of the rims below.
You can't say what will rub based on wheel size... depends on tire size. I can't answer your question though.
IIRC stock is 16x7 with a 30mm offset. The wheels in question are an inch wider and 20mm less in offset. They will "fit" but at full lock you might contact some of the steering or suspension components. That could be why they are saying they won't fit.
1 - 14 of 14 Posts
