This is a 2004 vg33e by the way. So for the last year, I've been rebuilding my Xterra's engine. I stripped it totally down to the block (while still in car) to replace my head gaskets. Because my coolant was foaming up and coolant was coming out the exhaust. There was no water in my oil. And certainly no cracked heads. I restored and repainted just about every part of the engine minus the block and cylinder heads. And every single hose on the car is also brand new. All the belts are new (even the timing belt), all the filters are new, all the fluids are new, it has new valves (I lapped them so don't worry), and most of the gaskets are also new. Even the valve stem seals. I had the cylinder heads resurfaced as well. I even added a catch can and will be adding another for the other pcv hose. I finally have it running again, and I look and see that there's water vapor on my oil fill cap and I see a small puddle of oil dancing under the valve cover (I could see it by looking through the fill neck. There's no more water coming out of the exhaust and it doesn't seem like the coolant (currently only distilled water) level has gone down at all. The engine is running great, I can send photos and videos later if needed. I've also heard that sometimes its normal to get a little water in the oil because of condensation. I mean there's been some seriously humid days here in Massachusetts so is this the case? Any help or suggestions would be amazing. I can't afford to take this to a shop to be worked on. Thats the reason I did all the work myself.
Thank you in advance
-Zach
-Zach
