Hi all
I think my rear wiper motor may be gone. Yesterday it quit on the way to work, stopped half way up. I got a chance today to look at it. I've got power to the box attached to the motor (relay?) .then I checked the connection to the motor. It reads 11.45 across the middle and outside terminals. One way plus and the other minus. So I suspect the motor is toast. Any thoughts?
Most of the time its in the wiring inside the rubber boot by the hinge from opening and closing the rear hatch . Remember the motor has 12 volts all the time and the ground is cut to turn it off and on.
That is good,now there is another wire that is the ground black wire that goes back up to the dash switch.
