Yes I will definitely check it out
Thar is theI tested the new genuine Nissan thermostat today and it works I put a thermometer in the water and it opened at 190°
What's the part # for the new Nissan thermostat you got & where did you order from, a local dealer? I thought the OEM for these is 180 deg. I'd love a 190 deg t-stat for my '03 - it takes forever to warm up in winter, but i haven't found reference to a 190 deg version anywhere.Well I replaced the radiator top and the oem Nissan thermostat
There are 2 camps about that statement, both equally insistent that the engine will run hotter or cooler. Both can't be true. I'm not convinced one way or the other, but if I had to guess, I'd lean toward the cooler side of the fence.... snip ...
Also, i'm not suggesting this is part of your original problem, but running withOUT a t-stat can make a vehicle run hotter, as the coolant shoots thru the system too fast for the radiator to cool it down.
... snip ...
In this discussion you have to keep in mind there is a "time" component involved in the transfer of heat or cold from one medium to another. Both in heating and cooling, the ability to remove heat from a fluid [radiator] or air passing over a AC cooling radiator[coil etc] is strongly influenced by the rate at which the coolant or air passes through the cooling device. The heat is transferring from one medium to the next and sufficient transfer is related to the time the two are in contact. Example: If you put a digital thermometer into one of your dashboard cooling outlet ducts and monitor the temperature of the output air, you will find a optimal fan speed that provides you with the lowest/coolest temperature output. Don't assume that placing the fan on high is providing you maximum cooling because you are likely to find it is not. If the warm air is passing over the AC cooling coil too quickly it does not have sufficient to time to remove the maximum amount of heat. I know....blah, blah...blah!There are 2 camps about that statement, both equally insistent that the engine will run hotter or cooler. Both can't be true. I'm not convinced one way or the other, but if I had to guess, I'd lean toward the cooler side of the fence.
A t-stat controls the flow on 2 circuits, not just to the rad. The part that opens to let coolant flow to the rad does so to help cool the fluid as the engine warms up. The other part of the t-stat that sticks out controls the amount going to the bypass. When fully open, the bypass is closed off; when fully closed, the rad is closed off; when partially open, the 2 circuits are open by varying amounts.
Without a t-stat, both are fully open, so the flow will be split more-or-less evenly.
One question I have about the coolant moving too fast and being less able to absorb heat: What happens when the engine is getting too warm and you shift down one gear to speed up the engine? Every car I've ever driven causes it to cool down, not get hotter. In my experience, moving the coolant slower makes it overheat, not moving it faster.
I'm not calling anyone out. I'm simply asking for a sane and lucid discussion so we can all learn and come away with a better understanding overall.
The warm, outside air passing over the AC coils is not the same as liquid inside the engine being in direct contact with the block. Air is more than 20 times less capable of removing heat than liquid, but we're not fish, so we cool the air. AC also removes humidity through condensation, which affects how well it cools. (I've heard that the figure is around 26, but "over 20" is a reasonably fair approximation.)In this discussion you have to keep in mind there is a "time" component involved in the transfer of heat or cold from one medium to another. Both in heating and cooling, the ability to remove heat from a fluid [radiator] or air passing over a AC cooling radiator[coil etc] is strongly influenced by the rate at which the coolant or air passes through the cooling device. The heat is transferring from one medium to the next and sufficient transfer is related to the time the two are in contact. Example: If you put a digital thermometer into one of your dashboard cooling outlet ducts and monitor the temperature of the output air, you will find a optimal fan speed that provides you with the lowest/coolest temperature output. Don't assume that placing the fan on high is providing you maximum cooling because you are likely to find it is not. If the warm air is passing over the AC cooling coil too quickly it does not have sufficient to time to remove the maximum amount of heat. I know....blah, blah...blah!
Yes.Will a 2003 super charged Xterra radiator fit my car. It is 1 1/4 thick like the original radiator I just wanted to make sure it is the one that will work
This guy! No wonder he only has 74k miles on his 2003 pumpkin. He lives on an island and every time he tries to go somewhere, he ends up at the beach!Yep. As a matter of fact, when I replaced the radiator in my 2003 Normally Aspirated I installed an SC specifically for that reason.
