Hey All,
I'd like to install a fuel pump kill switch as a safety/security precaution in my 2004 Xterra XE and wondered if anyone could provide some insight on the wiring. The idea would be to add an inconspicuous stock switch to the dash that would cut power to the fuel pump and prevent theft/car jacking, etc. We'll be taking our X through Mexico, Central and South America (and possibly beyond) this coming November and would like the extra piece of mind that we could surrepticiously disable the vehicle if we wanted. The fuel pump approach is preferable as a battery kill switch is more immediately obvious and easier to trace instead of letting them get a little ways down the road (and away from us!) before encountering a problem that could be caused by a lot of things.
My first idea would be to patch out of the fuel pump fuse near the driver's knee with an inline fuse and a switch. Of course, if someone removes the fuse panel to investigate, they would quickly see what's been done.
The preferred approach would be to tap into the fuel pump power source behind the fuse box but this requires knowing which wires in the harness are for the pump. I have the Chilton and am looking at the wiring diagram but could use a little help (see below).
Disclaimer: I'm learning this electrical stuff as I go but, it looks like the BLK wire is supplying power to the pump which connects to the relay and back to the fuse via the BLK/WHT. Would it make sense that finding the BLK/WHT and putting the switch there would do the trick?
Anyone have any other thoughts on how to achieve the desired result?
Thanks in advance for your input.
