1 - 2 of 2 Posts
Hello guys!
So, I have a manual 06 X OR with 77k. Just got A total clutch overhaul at a tranny shop. When I go to pick it up they tell me there is a issue with the idle and they don't know how to fix it. The code reader was spitting out a code for the IAC. So I bring the X home with plans to bring it to the local Nissan dealer. When I turn the X on it surges pretty bad. Goes starts at about 1400 then rises to 2400rpms then drops back down then goes back up and so on and so forth. I tried to do the re-learning but got no results. Plz help :)
Thank you in advance for your time.
2000 Xterra XE 4x4 3.3L AT
Well it sounds like an issue with the IAC (Idle Air Control). Do you know the code number? If you have the code number you can go through section EC of the factory service manual to diagnose the problem. The FSM can be found here.
1 - 2 of 2 Posts
