What's wrong with yours? Get yours rebuilt. It's a gamble with used but you could look at car-parts.com
I have slipping between 1st and second after it shifts into 2nd, then a hard shift to third, and I don't think I'm getting into 4th because I'm going 60 mph at 5500 rpm.
You can pretty much use any 00-04 4x4 transmission. How is your fluid level, color, and smell? Mileage? When was the last trans flush? Slipping could be due to low fluid or excess heat.
Idk when the last service was because I've only owned it for 2k miles. But, I did just drain about 7 to 7.5 quarts and replaced it and the filter. The fluid smelled burned and the magnet was covered in fine metal shavings that were almost like sludge
