1 - 7 of 7 Posts
Needing part number for the studs that hold the hub to the rotor. The measurements would be even better. Tried several parts places no luck with either. One kept asking if it was wheel lugs tried several times to explain but anyway Help please. Thanks
Good question...I have a wheel bearing job planned for tomorrow so I will snap some photos and measurements for you. Not sure on the part number from Nissan, though.
OK...So I didn't get a photo, but the bolt is a hex flange bolt with a flat washer. It was larger than an M8 and smaller than an M12 so I am going to say it is an M10.
The shank of the bolt was 30mm from bottom of flange to tip.
I am not sure on the thread pitch, but Nissan usually uses a fine-ish thread...so 1.25 or 1.50 thread pitch.
I would run to the local hardware store and buy one of each M10 bolt they have available and test the threads.
Nissan PN: 40207A - bolt
Nissan PN: 08915-2401A - washer
You could order them at the dealership if you want the original part
1 - 7 of 7 Posts
