Three of the four Torx screws that hold the gear/wet box to the rack are frozen in their brass inserts. The inserts just spin in the plastic when I try to remove them.
I've tried holding the underside of the insert with an angled pliers but can't get a good enough grip on them.
I need suggestions for removing the screws/inserts.
You could drill them out and replace them with helicoils, etc.
try carefully cutting the plastic off the square heads of the bolts [hacksaw]. that way you can get a grip on the bolt head with vise grips and screw them out. that's what I did. saves the threads in the roof rack.
