Removing that cap is the same as taking the cap off of a tire. Nothing should leak out until the actual valve that it protects is depressed. If they didn't depress the valve under that cap, then removing that cap should not have made the AC fail. If it did, then that valve has an issue.
Download the free FSMs for guidance on how to do the AC. It's not as simple as just adding freon. You can get them at the link in Post #10 below.
www.clubxterra.org
Help CX To Help You!!
This takes less than a minute to do so help everyone out and add your truck Year, Model, Engine Size, and Transmission Type to the VEHICLE DETAILS in your profile. It will then show up right under your name in every post you make. 3 steps easy and simple and it will help to avoid...
