I've seen a few different versions and I've always got stuff and more stuff that I like to keep in my X; so I'll share how I made my snazzy LOBO Rack. It makes a great place for keeping my safety gear for visiting job sites, recovery gear, etc...
Goal Of Build:
-Keep it simple & make it nice; keeping it around $50
-Super easy install, no drilling/cutting
-Easy to remove if you need the extra space
-Strong with usable space, adjustable
-Full Drop for access when needed
-Provide enough drop for items and still keep line of sight when in "up" position
--went with about 5" of drop from the bottom of factory clips
Materials:
QTY: COST (ea.): DETAILS:
(1) $14.95 Closetmaid Shelf 48"x16" (Model #73570)
(1) $4.95 Closetmaid "Closet Rod" Attachment (WHT)
(2) $2.19 Parachute Buckles (BLK)
(1) $5.00 60" Roll Nylon Strapping (BLK)
(1) $6.95 Snaps & Fastener Kit (SLV)
(1) $2.95 Small Metal Eyelet Kit (SLV)
(4) $2.50 5/16" Quick Link/****** (SLV)
(1) $9.99 Can Spary Bed Liner (BLK)
(1) $1.35 Roll Vinyl Tape (BLK)
Total Cost (if you have NOTHING): $58.33
Hardware you can get from places like Home Depot/ACE. The stuff to make the straps I got from Jo-Ann Fabric & Crafts. I tried Michael's first because it was closer, but they didn't have much at all.
I already had some plasti-dip, vinyl tape, and the closet rod attachment from other projects. I ended up just vinyl taping the the quick links, didn't have enough plasti-dip left, and it was way easier and keeps it just as quiet. Plus, when it wears it'll be really easy to re-do. I think the extra cost of the spray bedliner was worth it, I let it dry for 4 days after I sprayed everything. It looks good and grabs a hold of stuff.
Instructions (w/pics)
Here's the shelf & sticker...
It matches the gray interior nicely, too bad the bar attachment only came in white.
More Materials...
Idea of how the bar will hold stuff in with the straps holding it up...
Time to start making the straps...
-Used about 7" +/- for each nylon strap
-After cutting the straps I dabbed a little glue on the edges to keep it from fraying
-Started laying out which end I wanted male/female
-Threaded the straps before attaching snaps & eyelets
--once you set these the buckle isn't coming off
Setting the snap fasteners in the straps...
-Cut a little hole in the nylon, then put the snaps through & set
-Folded the adjustable end back on itself and secured with eyelets (keep it from sliding all the way out, just in case)
Finished product of all the straps...
-The female end straps have double snaps and go around the base of the shelf
-The male end straps loop through the factory hooks at the top and hang down, fully adjustable
Final Product...
-Everything is sprayed, taped, and spaced to be installed
Before Install...
Installed...empty rack
Installed...loaded in the "Up" position
Installed...loaded in the "Down" position, full drop
View from the Driver's seat back
View from the Rear View Mirror
And that's that, take your time with snaps, and measure to get them to line up where you want them. The adjust ability is great too, try washing the nylon straps first if it's too slick. The nylon had some slick coating on it out of the package. I washed the straps in the sink and roughed em up some playing with them, no slippage problems anymore. Of course, you could always add another snap on the back too.
Safety/Emergency Tool Install:
...kind of related, installed a nifty safety/rescue tool I saw at the hardware store for $15. It's one of those window punch & seatbelt cutter combos. It came with nice mounting bracket and fits perfectly in the underside of the center console with a little trim to the plastic mount. Here's a few pics...
Under console...
Console still closes fully...
Easy to grab...
Enjoy!
:3d_004:
Goal Of Build:
Materials:
More Materials...
Final Product...
Before Install...
Under console...
Easy to grab...
Enjoy!
:3d_004:
