1 - 20 of 101 Posts
Hi everyone, I'm trying to figure out the average miles that people have on their x. Even if you have a buddy who has an x and isn't a member on the forum ask them to see how many miles they have on their x. My goal is to figure out a dependability rate for our trucks. So post a pic of your beast with the year/model and how many miles it has on it. I will go first.
2004 xe
163,466
Thanks everyone for your help
Your my twin....
2003 XE
128000
Timing belt and all the crap in that area, rotate and balance, ac lines had to be changed when I bought it, and thats it
Sent from my DROID RAZR HD
Cost In Maintenance Till today(parts only)
2002 Xterra - ~128,000 ~$400 Oil, Brakes, Timing Belt kit (it needs an Low Pressure AC line and Heater core)
2001 Xterra - ~132,000 ~$700 Oil, Timing Belt kit. Spark plugs and wires, Radiator,Hoses PS Line
Note* When 2" BL I broke the heater core.
2000 se with 149k. The only repairs I have done that wasnt a result of me doing something were shocks and distributor. However my ac doesnt work very well, and one of my heater core hoses has a really slow leak.
2001 SE
110,000 Miles
Outside normal maintenance I've had leaking power steering lines, radiator hoses, and AC lines that is pretty much it.
2004 XE
127,000
Annual MX (not upgrades) ~ $400 AC line, filters, etc.
Major MX - Replaced Timing Belt, Water Pump, Brakes at 107K
2004. 139,000 mi
Timing belt and all that jazz done around 129,000
Owned it since 19,000 mi, spent less than $500 on repairs in 8 years
Sent from AutoGuide.com App
Reactions: Kuroi_tora
My '04 Xterra XE has a bit over 151K miles on it at this writing. I put anywhere from 1K to 2K miles on her per month. I bought her used in October, she had about 135K on her. Outside of standard stuff she is going under the knife to get the timing belt done along with her other belts. Cost of the timing belt kit was $111. with tax. I am not sure what the other belts will run. And a friend is going to help me with the labor.
2011 Pro4x with 50,000 miles
Stuff I have done:
Cleaned corrosion from battery terminals, and the usual fluid and filter changes
Sfuff I haven't done:
Replace cracked windshield
Replace broken latch on overhead door for sunglasses
Repair the intermittent problem with my windshield washer not working
Close to 140k on mine, had it since October 2009 @ 97k.
Maintenance and repairs (some of this was preventative/while I was in there/I wanted to):
timing belt/water pump
power steering flush
front wheel bearings repacked
driver rear axle shaft replaced
tune up
fuel filter
PCV valve
replace power steering clamps
driveshaft rebalanced and greasable u joints installed
unclog rear diff breather
front sway bar end links and frame mount bushings
tranny rebuild/clutch
camber bolts/eccentric washers
upper and lower ball joints
tie rod assemblies
exhaust manifolds
way too many alignments
tranny/diffs/transfer case fluid
2 O2 sensors
Off the Beaten Path
2002 xterra
187,000ish
Maintenance so far has included:
Timing belt replacement/repair (blew up on me first week I owned it)
Switching the fluids
Rebuilt tranny
Tune up
Couple of axles and some brakes
Lots of oil changes/alignments
Air filter
Ball joints (up and lower)
O2 sensor
And body repair from a crash (New fender,hood,bumper)
2000 XE with 121000 mi.
Did Timing Belt at 105k and about to do the 120k full fluid change in the driveway. Other than that I've only had to replace a windshield wiper linkage last winter and the AC is in need of a low pressure line/recharge. Truck runs flawlessly!
1 - 20 of 101 Posts
