Hello everyone, new member here! Here's what I am dealing with;
2003 non-SC Xterra V6 Engine
Rear-Wheel/4x4
Automatic Transmission
126k miles
Recent maintenance/repairs:
Fuel Pump/Filter replaced
Spark plugs changed
Throttle Position Sensor replaced
Distributor rotor/cap changed
Knock Sensor replaced/relocated
ATF drain and fill
Radiator replaced
I have two main concerns with my Xterra, but I'm just going to point out the most concerning;
After replacing the knock sensor and the throttle position sensor, I decided to check all of the fluids to make sure everything was where it was suppose to. When I went to check the automatic transmission fluid, there was nothing on the dipstick. So without hesitation, I topped it off with about a quart and a half or so. From there on out, it hasn't been that low, and fluid has stayed the same, so I'm not sure where it went before. Now I'm experiencing a couple of issues, which I am afraid might be transmission related, which I don't really need right now....
First, there is a surge that occurs, only when I hit 15 mph, and only when I am going slow. If I push on the gas pedal hard enough, I can bypass that surge completely. The surge makes the RPMs go up anywhere between 2500-3000.
Second, the RPMs are a lot higher than what they were before, specifically around 40 mph and 60+ mph. At 40 mph, the RPMs sit at close to 2000 RPMs, and when I start to approach 60, they're nearly at 3000, and continue after that. I know that this wasn't how it was when I first got the car, so it's really worrying me that it's a transmission issue.
Any thoughts on this?
Rear-Wheel/4x4
126k miles
Spark plugs changed
ATF drain and fill
Radiator replaced
