I have 2004 X with oem step rail, with tires the X sits pretty high for the stock sissor jack, i have a high lift jack, where is the best spot to lift the car from, i have to remove the back tire to work on my evap canister but im reluctant to put the jack on the step rail, any suggestions?
Brooklyn br0
Your oem step rail will not hold the weight of your truck. Do not try. You can get a hi lift jack tire strap, lift it from the tire and put a jack stand under the axle...
2000 Xterra XE 4x4 V6
As Bklyn.X said the only way to utilize a Hi-Lift in your trucks configuration is with the wheel strap. Once lift it you would have to put a jack stand under the axle tube to support it while you remove the tire then work.
I only use the Hi-Lift while on a trail. For maintenance work I Have a floor jack and jack stands. Hi-Lift jacks are cumbersome and slightly sketchy but are the only decent reasonable option on a lifted truck while out on the trails.
Discussion Starter #4
Dint even cross my mind to try lifting from the step rail, thank you for the input, i fairly new to high trucks and first time owning a high lift jack, was not aware of the strap, will look into it, thank you!
Discussion Starter #5
Thank you, im deff investing on a floor jack, is the set up mentioned your road side emergency set up aswell?
