Welcome! Valve cover gasket is a culprit. Also check your PCV system.
As far as P0744 on Nissans it's an indication of a fault in your torque converter. First thing, check the AT fluid. Idle the car until warm, then pull the transmission dipstick while it's running, in PARK. If the fluid level is correct, but brown/dark, then replace the fluid first.
