1 - 7 of 7 Posts
2003 Nissan Xterra
Hi all,
I just got done installing my NiLight Pods, and they look sick! Anyway, parts I used for this project include:
1. NiLight Pods
2. NiLight company wiring harness set.
They light up everything, but after letting the vehicle sit a while, and i start it up again, it has a roughish start, and I have reason it could be the lights causing problems to my battery..
Couple things to note, I plugged the wires everything correctly, and switched the fuse to a 10A. I did notice my negative terminal on my car battery can easily (with some force) move back and forth..
My question:
Should I have plugged the wiring to my ignition switch so when the car is off, it doesn't draw?
Or
Is the way I wired this in, is correct?
Thank you.
If more info is need, I'll gladly answer.
That negative battery terminal being able to move at all is a bad thing. Vehicle start draws a lot of current and a loose terminal will seriously limit the amount of current that the battery will be able to pass along to the starter load. Tight is right!
2003 Nissan Xterra
Copy. Before I tighten it some more, I think my negative terminal on my NiLight cable is somewhat preventing this from tightening. Any advice?
I'll try to mess with it right now in the mean time. Thank you
Find another ground location to connect your NiLight ground cable to. No need to cause interference with a good tight connection for the negative terminal of the battery. Use a frame ground or engine ground connection. You will find both with existing connections that already run to frame or engine ground.
2001 Xterra 4WD Auto 3.3L V6
Put a pair of Vise Grips on the negative terminal and see if it starts better. If it does, then the terminal is the issue.
03 XE A/T, SC coming soon
this is very important and often overlooked. Remember the terminals are cone shaped so the farther down they are, the tighter they can be.
this is also good advice to quickly check it. Voltage drop can also be measured here using a DVOM
2003 Nissan Xterra
Discussion Starter #7
Thank you all for your help. I disconnected everything... (Off-road light wise)... And ran a screw through the terminal. I'm having my bro-in-law's neighbor help me install a new terminal tomorrow, and this one has better connections for the NiLights to plug into. I appreciate all of you! Thank you.
1 - 7 of 7 Posts
