The reason i joined this forum is i found an xterra 4x4 with 221k on it at a dealer as is listed for 4750. It looks well maintained. Havent signed on the dotted line. Will be checking carfax, climb under etc.
Any thoughts, tips, would you do it ?
Im thinking i will talk them down a bit if i can ( price wise ).
Thank you
Lynn
Run it through its paces. Run it through all the gears, put it in 4 hi and 4 low...run it through all the gears. Turn the wheels all the way, left and right, under power and listen for any any weird noises (roughness or grinding). Look for any body damage...any evidence of a crash. Look for any leaking fluid from the transmission, transfer case or around the oil pan area. Take it to a mechanic for an inspection and ask the dealer for a carfax report.
I sure will ! I just read alot good reviews on this vehicle and i was hesitant about the high miles. It looks like someone took really good care of it . Thanks for your advice, greatly appreciated.
