1 - 17 of 17 Posts
I bought a 04 x mid summer, as the weather is getting cold I have flipped on the heater. OK so it don't matter what setting it is on the all blow hot( defrost vent and heater) there is a constant cold air blowing on passenger floor board. When I push the recirc button it warn a lil there, all other positions blow hot, I does not have dual climate. I don't understand.
One bad feature of the xterra the a/c is on all the time most people unplug the a/c at the compressor for winter time.
I don't really understand that answer, I will try it, I am wondering if maybe the blender action, but even that don't make sense unless it is a dual climate and the pass did isn't moving
Curious about this. I thought the AC was only on if either:
1. AC button is pushed or
2. Any defrost mode is selected (even w/o ac button pushed)
Discussion Starter · #6 ·
I will try it and let ya know, and no my AC button is not on and it does blow cold at pass feet at all times and positions.
Discussion Starter · #8 ·
I may understand that as it recycles cold into heater core to heat, why is it excaping into pass floorboard tho, I have owned over 40 vehicles of all kinds and not one have ever done this?
Discussion Starter · #10 ·
I looked quit a bit to see if I could find a answer before posting it. I couldn't see any. I will respond on outcome this evening on the AC plug
Discussion Starter · #11 ·
OK so I unplugged the AC pump, and it did nothing as expected it woupdnt, I think it is something inside the cab, any other suggestions
Can you hear the door close on both sides when you change from def to a/c ?Just put the key on no engine.
Discussion Starter · #13 ·
OK, so u have located my problem, upon taking the glovebox off there seems to be a broken part on the lower fan housing that is blowing the outside air into this area. Cheap Nissan parts anywhere?
Dejablue is like a walking Xterra bible! Nicely done and another happy member!
Ok, I'm going to tag on to this post.
I also have a similar issue, it seems that no matter what position it put the air/ heat vent dial in the air just comes straight out from dash, I can not get heat into the foot wells, and minimal on driver side windscreen. Is the dial a mechanical connection on is it electrical?
Nissan Xterra 2009, thank you.
The cable clamp my have come loose and the vent door is not opening and closing.
1 - 17 of 17 Posts
