*UPDATE***
Today i decided to try and access the control switch by removing the dash, I was able to remove just the center parts to be able and disconnect it and plug it into the used one i have bought.. Still does not work, so decided to test the connector itself and make sure there is power going to the control switch itself, NO POWER!!! After triple checking the fuses in the fuse box inside the car, we decided to test the fuse box itself. Only the LEFT HALF of the fuse box has power and the other side does not have any power...
So, for a temporary fix we connected a fuse on the left side (that was not being used) to my blower fuse on the right side with a wire that had a fuse between the two.. and that made everything work just fine.. Guess i may have to replace the fuse box itself..? Or something bad in my wiring is causing this.. Either way, for now i have a heater!!
I hope this may help anyone who has a similar issue, when the common things that go wrong are not fixing the problem.. Also, wanted to thank everyone for the feedback to my original message...:icon_rolleyes:
