Bump. Someone has to know how to do this. I've seen finished products, just no write-ups.
Buuuuuuuuuuuuuuuuut...... That Xterra in the write-up doesn't have a sunroof, so it's of no help to this specific question.Here is a nice video.
http://www.clubxterra.org/forums/showthread.php?t=31335
Yep just take a pudy knife and start working around the edges.i think the key here is a big steady work table maybe a 4/8 plywood and a second person.Thanks guys. Just wanted to be sure it wasn't more complex than that. Does the trim just pull out and go right back in then?
Perfect, thanks.Yep just take a pudy knife and start working around the edges.i think the key here is a big steady work table maybe a 4/8 plywood and a second person.
I did mine on the garage floor with some plastic sheeting beneath. BACKBREAKING! if you can get a table big enough, do so.Yep just take a pudy knife and start working around the edges.i think the key here is a big steady work table maybe a 4/8 plywood and a second person.
