Tape off the lights, Use 1500 Wet/dry sandpaper ONLY, even if the headlight defects are severe, this is becuase the lower grit creates deep grooves as well, and is sometimes a lot more work to get out. Get the headlight to a smooth white haze then use a high RPM buffer (1500 plus) with Turtle wax Brand Polishing Compound. Be careful, not to spend to much time in any spot as to NOT burn the plastic.
2001 se 4x4 5spd 32"
I would suggest using a UV blocking clear coat after cleaning them up.
Keeps them clear much longer.
