auto or manual? 4 cyl or V6?
The factory manual shows the location of the PNP switch here on page AT-99:No I dont think I ever checked the switch, im assuming its somewhere near the transmission? The Haynes Manual isn't very clear on its location...
You aren't bypassing the ignition system, you are bypassing the starting system and its associated relays and switches. All that does is verify what you already know: your starter motor works. You still may have a problem with your starter relay, your PNP relay, your theft warning relay, your ignition switch, and all the associated wiring. (edit: start by checking your starter relay for control power first. If it has voltage to the control side, and voltage to the positive power side, then it can be nothing else but the starter relay and / or the negative battery cable)Would that stop the starter from starting even though Im bypassing the ignition system? With the switch I am running power directly to the solenoid and Im still getting the single click.
Not that this is the issue, but voltage isn't the only thing you need. You need amperage. A damaged battery can show 12 volts, but have a massive voltage drop when you put a load on it. If you had the battery replaced then I wouldn't consider the battery to be the problem, but that doesn't mean that the wiring is up to par. I know we've gone over this before, but corroded battery terminals or damaged connections can cause intermittent problems. They can usually be detected by shaking them around. Broken copper strands in a large cable will still show 12 volts but may not "carry" the required amperage (resistance too high).Yeah I checked the voltage of the battery in multiple places and its gets essentially the same amount all the way down to the starter, maybe 0.1 less.
Make sure you check both ends, not just the battery side connections.I replaced both terminals and they are quite snug on the battery posts (one of the other times I had this issue it corrected the problem for a little while).
Yes, if you apply 12 volts to the control side of the solenoid, you should get continuity (measured with a multi meter) across the two high amp posts of the relay if it's working correctly. Ground is the starter body.Ive taken the Starter (with the Solenoid attached as they are essentially one unit) to the part store it will turn over every time, is there a way to test it separately to show them its defective?
