1 - 2 of 2 Posts
Just traded my 2001 X for a 2004. On a 2004 is there a steering stabilizer? also, the front end needed some work, along with 4 new tires, so it got a new alignment. the front needs to be brought up a little to level it out, will I need a new alignment if I do this.
There is no steering stabilizer stock. There are after market ones available but they simply hide issues more than anything.
There is suppose to be a 1-1.5" difference in height from the rear (higher) to the front (lower), which supposedly improves handling and aerodynamics slightly. Just wanted to you to know the front being lower isn't an issue unless the rake is more than 1-1.5".
To "fix" that rake the torsion bars can be adjusted to bring the front of the X up. Just be sure to leave a .75" gap from UCA to bump stop to prevent issues from occurring.
1 - 2 of 2 Posts
