1 - 13 of 13 Posts
Wish it would be an easy swap into my 01...it would definitely help with the midrange bass...hmmm, got me thinking
Darin
01 Xterra SE 4x4
COMING SOON:
Wish list:
Does this mount in the back on one of the side panels? How much you looking for shipped?
Read Only
Darin
01 Xterra SE 4x4
COMING SOON:
Wish list:
Hi Darin
Not sure you would have to find out or remove the rear panel to see if there is space .
I only have an opening for a 6x9...so no I doubt it would...but I haven't found any info on it being possible yet
Darin
01 Xterra SE 4x4
COMING SOON:
Wish list:
Read Only
Discussion Starter · #7 ·
Darin
01 Xterra SE 4x4
COMING SOON:
Wish list:
Darin do you see 4 nuts where it can be bolted in ?
you can tap new holes where it would normally bolt in.....BUT.....you will also need the plastic cover panel as well as yours wont fit with the sub. I have the sub from the factory and this is how my back panel looks. notice the extra bulge in the panel.
Ya...plus then wiring and all...maybe I'll just go for an underseat option
Darin
01 Xterra SE 4x4
COMING SOON:
Wish list:
Read Only
Discussion Starter · #11 ·
Darin
01 Xterra SE 4x4
COMING SOON:
Wish list:
The sub has the connection it was cut out maybe 5 inches after connection .
Yes you would need the cover with a bulge to go around the sub ,
hi d grade
mine was on the rear driver side ,4 bolts held it in place
what is you postal code i will check for shipping .
85225 :)
1 - 13 of 13 Posts
