I live in Brasil and have a diesel Xterra 2005 with less than 70k Miles. The front lights need to be adjusted but the screws to do so are not working. I need to remove the lights set in order to fix these bolts. Can anyone, please, tell me how to remove them?
Thanks a lot for the manual.
For what I understood, one must remove the front bumper in order to take off the Headlamp assembly, is that right?
not remove, just un bolt and wiggle around its a pain but can be done without bumper removal. and those adjuster screws take tons of turns before they actyually do much, adjusted mine and had same issue, they didnt seem to do anything then after like 30 turns started actually adjusting, if i recall they were reverse of normal screw too, so left was tight and right was loose i sprayed wd-40 on mine and that helped alot
